Old 02-08-2022, 06:24 AM
71 RAT's Avatar
71 RAT 71 RAT is offline
Default Loose Feeling In Corner
I been battling this loose feeling into a corner, basicly feels like an over loaded truck! Quick info for rear suspension ;
Currie lowers arms and adjustable uppers
Hellwig adjustable sway bar
Poly bushings in upper rear housing
QA1 single adjustable shocks
GW 130 springs
Air lift bags about 5psi
Things I tried;
Check all bolts and fasteners, several times
All 3 positions on rear sway bar, have not disconected it
Tire pressure
Air bag pressure
Firm up shocks
Recheck rear end is centered
Alginment is;street performance
camber: -1/2
caster: +5 to +5.5
toe in: 1/16" total
Nothing made any difference, one way or another. The 295/45/18 tires are pretty close in the wheel wells, if the rear housing was moving much I'd think there would be a rub. I'm planning on swapping the poly upper bushings for UMI Roto Joints, or something similar. Had some spherical type in that position but the NVH was not tolerable.
My Tacoma with a 2" lift and taller tires doesn't squirm around as much.
I had the suspension set up for street strip deal, years and years. I lived with it, figured it was set up to try to go straight. The rear always tries to pass the front! YEEHAAA!!
Following up on some info from on Team Chevelle. My left tie rod assembly on the drivers side is 5/8" longer than the passengers side. Obviously the steeringbox is not centered, idler arm and pitman arm are not parallel front to rear. I borrowed a bumpsteer gauge, haven't set it up yet, but on the list of things to do.
Do you think the 5/8" difference with my tie rod assembles is partly or the source of the uneasy feeling I'm experiencing?
Thanks for all the suggestions.
71 SS 454 TH400 2.74 1st gear GV Overdrive 3.55 Gear SC&C Stage 11 QA1's 4 Wheel Baer Brakes AGR Box Straub SR .630 .612 lift 240 256 [email protected]
83 K20 454 TH475 NP 205 Dana 60 Track Lok Detroit Locker Rear
58 Ford 821 Powermaster Loader Backhoe Restored Family Heirloom
Old 02-25-2022, 06:22 AM
71 RAT's Avatar
Been very busy, only have had a few hours a week to work on the Chevelle. Steering box, colum, and wheel, belive I have all centered. The Idler arm wasn't greasable and hitting the sway bar. Picked up a Snapa premium, swap it out before setting the toe. Considerable difference here! Anybody have an idea what, if any ramifications, this may cause?
Old 02-25-2022, 03:52 PM
I'd check to see if the rear end housing is square in the chassis.
Old 02-28-2022, 09:35 AM
71 RAT's Avatar
I have adjustable Currie UCAs. I set it so the rear tires are an equal distance from the frame. Who knows how far off these cars when they slapped them together!
Old 04-20-2022, 07:53 AM
pannetron's Avatar
pannetron pannetron is offline
With that (good!) amount of caster, I suspect you may have a bump steer problem.
The Following User Says Thank You to pannetron For This Useful Post:
camcojb (04-21-2022)
