Old 02-11-2022, 08:50 AM
68454RS's Avatar
68454RS 68454RS is offline
Default Drill bits, what's good?
I burn up bits, any recommendations on a good brand of bits that last?
Old 02-11-2022, 12:01 PM
ErikLS2's Avatar
ErikLS2 ErikLS2 is offline
I've had really good luck and long term use with Snap-On. Recently ordered some of these for work and they seem really good too.
https://www.amazon.com/Norseman-4417...ustomerReviews
Cutting oil is your friend, use it every time and if the bit isn't cutting (producing chips) it's quickly being dulled (is that a word?).
Erik
69 Camaro
Old 02-11-2022, 03:20 PM
joeko23 joeko23 is offline
I also burn up almost all my drill bits. I now try to use step drill bits whenever I can as they have lasted the longest for me. I get a 3 piece set from harbor freight.
If you need a long drill bit, I’ve seen these drill bit point bits. They are more expensive but should last way longer than normal bits. I plan to buy them once all my normal bits are burned up.
Norseman 22903 1/16 in. - 1/2 in. Super Premium Black and Gold Oxide Hi-Molybdenum Steel Drill Bit Set, 29-Piece, grey https://www.amazon.com/dp/B08X95SCT7...ing=UTF8&psc=1
My Very Ambitious 69 Camaro Build
https://www.pro-touring.com/threads/...d-0-Fab-Skills
Old 02-11-2022, 05:33 PM
camcojb camcojb is online now
All my bits are cobalt, seem to last longer than anything else I've tried.
Old 02-12-2022, 06:58 AM
68454RS's Avatar
Thanks Guys, and from what research I've been doing, definitely the Cobalt with 8% which are the M42's. Those Norseman get great reviews
Old 02-12-2022, 06:54 PM
Chevy Kid Chevy Kid is offline
Chicago Latrobe or TRW are great brands in a couple different grades. Also try slowing the drill down, and as mentioned, cutting oil!
Tim
Old 02-12-2022, 08:28 PM
TechNova TechNova is offline
drill slow and use pressure, The heat is removed with the chip, if you are not making chips you are just rubbing creating heat that destroys the bit. Pilot drilling is also hard on the next bit. I make a dimple with 1/8" then use the final size. I have been using Max Winter Drill Bit City, don't know if he is still around haven't bought any in a few years.
Old 02-12-2022, 09:41 PM
Beechy's Avatar
Beechy Beechy is offline
Snap-On are too sharp and too brittle. You will never see a machinist using Snap-Off drilling/cutting tools. Same goes for their thread cutting taps and die sets.
AVOID AT ALL COSTS.
McMaster Carr or MSC are your friends here. Order the black phosphate finish as it carries lube to the cutting flute.
Cobalt is brittle but necessary for harder materials or broken tap removal.
Harbor Freight has the best/cost effective step drills.
Jim Grant
Melbourne, Australia
(Dual citizen)
The Following 2 Users Say Thank You to Beechy For This Useful Post:
68454RS (02-13-2022), dhutton (02-14-2022)
Old 02-14-2022, 12:46 PM
ErikLS2's Avatar
I've never heard of a drill bit being too sharp. I have beat the crap out of Snap On bits for years.
Cutting oil, make sure it's always cutting, and sharpen as soon as they even start to get dull, Drill Doctor works great, and you can make most good quality bits last a very long time.
Erik
69 Camaro
The Following User Says Thank You to ErikLS2 For This Useful Post:
zz430droptop67rs (02-15-2022)
Old 02-15-2022, 05:09 PM
zz430droptop67rs's Avatar
zz430droptop67rs zz430droptop67rs is offline
I'm still using a Snap-on drill set I bought in 1978.
As said above, keep them sharp.
