Old 02-17-2022, 05:34 PM
Screaming-Chicken's Avatar
Screaming-Chicken Screaming-Chicken is offline
Default Off the Floor GM Dimmer Switch
Just added this product to the website today. It's a wiring kit and billet button to get the dimmer switch off the floor. The switch uses a small 19mm button instead of the foot operated switch on the floor. We include a relay harness with color coded wiring for an easier install. You can locate the button wherever you can drill a hole, it can be right near the headlight switch, or you can hide the button in the ash tray or center console. Designed for 1st/2nd gen Camaros & Firebirds but could be made to work with any GM with the floor mounted dimmer switch.
https://screamingchicken.com/1967-69...dimmer-switch/
The Following 3 Users Say Thank You to Screaming-Chicken For This Useful Post:
camcojb (02-17-2022), RdHuggr68 (02-17-2022), WILWAXU (02-20-2022)
Old 02-17-2022, 06:30 PM
camcojb camcojb is offline
Great idea!
Screaming-Chicken (02-18-2022)
Old 02-18-2022, 02:27 PM
Zspoiler's Avatar
Zspoiler Zspoiler is offline
The 1981 Chevrolet G bodies and later had them on the column ..It probabaly be adapted to the earlier cars
Old 08-30-2022, 03:36 PM
Made a quick bracket to mount the button in the ash tray for an install at our shop recently, works great since I don't smoke.
The Following User Says Thank You to Screaming-Chicken For This Useful Post:
camcojb (08-30-2022)
