Closed Thread
Old 03-14-2022, 04:50 PM
edge04 edge04 is offline
Default 1966 Pro-Touring Nova Project
Item Location (City/State): Delavan/WI
Description: Rebuilt 408 iron block LME stroker
Callies crank
Callies rods
Wiesco pistons
Arp fasteners
TEA stage 4 ls cylinder heads
Ls series water pump
Ported ls7 oil pump
Dual timing chain
MLS multi-layer steel head gaskets (7 layer)
ls f body oil pan
custom ported LME intake with elbow, fuel rails, throttle body,96lb injectors
Custom twin turbo kit
2-62mm precision turbos
waste gates
custom turbo headers
Bell custom inter-cooler
New Jakes Performance 4l80 E stage 3
Shift controller
D3 transbrake
Billet Converter 3000-3200
New Moser Ford 9 3.25
PSC power steering pump, located in wheel well
Ring Brothers battery charging port
Marquez taillights
Fesler door handles
NewGen 3 pc Spyder Rims 18x8.5 fronts and 18x10 rears
Griffan Custom Radiator
Rick's. 15 gallon with a A1000 in-tank, -10 feed and -8 return with 2 vents
TCI Front Clip
14 inch rotors
6 piston wildwood calipers
450 springs
TCI 4 link
300 springs
4 piston wildwood calipers
Custom drive shaft safety loop
Ididit steering column
ISIS wiring module, need to be installed
Hydratech hydraulic brake assist and ceramic coated brake lines
Ring brother custom hood hinges with built in pockets
Bumpers were shortened, bolt holes covered, tucked into body panels, and half moon cutouts for exhaust
Cowl hood fitted for Trac Spec Vents and hood latches
Custom dashboard fitted with Racepak digital dash, and gauges
Underneath sprayed with lizard skin
I have many more pics and guessing I've left some parts out. Most everything is new. No interior aside that it comes with 2006 Corvette seats. Needs engine wire harness, a drive shaft, exhaust from headers back, front clip and bumpers painted, and final assembly and someone has a badass Nova with over 800hp on pump gas!
Old 03-15-2022, 06:05 PM
added some more details to the description and some more pics
Old 03-27-2022, 02:40 PM
Sold!!
The Following User Says Thank You to edge04 For This Useful Post:
camcojb (03-27-2022)
Closed Thread
