Old 03-25-2022, 07:27 AM
68LS1's Avatar
68LS1 68LS1 is offline
Default Vintage Air BBC Replacement Parts
Not quite sure where to post this?
Friend has a Vintage Air Front Runner system on his big block Chev, which needs a new water pump, listed Part No 72213-BCR, and alternator listed Part No 040707.
With a meet in a couple of weeks that he is very keen to attend, he has been quoted no stock available for months.
Are there other replacement options?
Is the alternator a Mechman unit?
thanks
Roger
68 RS Camaro Convertible LS1 6 speed
72 C10 SWB Stepside, old skool 350 4L60e
71 K5 Blazer 350sbc T350
Old 03-25-2022, 10:00 AM
ADY's Avatar
ADY ADY is offline
I had to replace my mechman alternator on my SBC and couldn't find anything that fit my front runner setup. Had to call mechman directly and worked with a rep to order build to order setup... not cheap and took 3 weeks to get it shipped.
Appears Jegs lists the part in your case with an estimated 4/2 ship date direct from Mechman most likely... no clue on international shipping: https://www.jegs.com/i/Vintage-Air/960/040707/10002/-1
-Adam
1968 Camaro SS
The Following 2 Users Say Thank You to ADY For This Useful Post:
68LS1 (04-01-2022), camcojb (03-25-2022)
Old 03-25-2022, 10:21 AM
dontlifttoshift's Avatar
Mechman can rebuild the one you have. If you go the rebuild route, I highly recommend having them change the regulator to a 3 wire setup. Every failed 1 wire Mechman I have seen has been the regulator. I have yet to replace a 3 wire unit.
The water pumps come from Stewart. They may not sell you one but they might rebuild the one you have.
Donny
The Following 2 Users Say Thank You to dontlifttoshift For This Useful Post:
Old 03-30-2022, 05:42 AM
130fe 130fe is offline
Thumbs up
That sucks about the replacement parts availability for the VA front runner stuff. Have you considered changing to the Holley Mid mount setup for the BBC? It is very similiar to the VA setup but uses more OEM style parts (cartridge style water pump) and the alternator puts out over 100 amps at idle. You also have the option to go with different finishes depending on your build. I have a couple of friends that have the SBC version and love it. I have the LS version in my car.
https://www.holley.com/products/engi...parts/20-242BK
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
The Following User Says Thank You to 130fe For This Useful Post:
68LS1 (04-01-2022)
Old 03-31-2022, 02:34 AM
Bad Bowtie Bad Bowtie is offline
Here's a quick look of the Holley mid mount on my BBC. Only thing I've noticed is the nose of the water pump protrudes out further than the VA frontrunner so this could be an issue with the clearance of the electric fan you run.
BB
The Following 2 Users Say Thank You to Bad Bowtie For This Useful Post:
68LS1 (04-01-2022), camcojb (03-31-2022)
Old 04-01-2022, 03:20 AM
68LS1's Avatar
I have installed the Holley mid mount systems on both my LS3 70 Camaro and 350 SBC C-10, awesome units. I have suggested it as an alternative to my mate.
We are located in Australia so shipping etc comes in to timing also
Roger
The Following User Says Thank You to 68LS1 For This Useful Post:
130fe (04-04-2022)
Old 04-01-2022, 06:14 AM
68LS1's Avatar
There is a thought that EDL-8854 can be used, https://www.summitracing.com/parts/edl-8854
I am unable to confirm the depth of the Stewart pump. The Edelbrock is 5.750"
Is anyone able to advise
Have an auto electrician that is going to replace reg in alternator to see if that fixes the intermittent voltage drops.
thanks
Roger
