Old 04-19-2022, 05:55 PM
Paraman1 Paraman1 is offline
Default Difference between Holley Terminator LS and Terminator X LS?
I am trying to figure out what the difference between the Holley EFI Terminator X part number 550-903 and the Holley Terminator LS MPFI kit part number 550-608 are?
Old 04-19-2022, 06:21 PM
Tinker's Avatar
Tinker Tinker is offline
The 550-903 uses the terminator ecu or xmax ecu that will also control single wire DBW throttle and electronic transmission control.
The 550 608 appears to use a hp ecu.
Double check what ecu is included with the kit you choose.
Chris
The Following User Says Thank You to Tinker For This Useful Post:
camcojb (04-19-2022)
