Old 09-15-2006, 11:42 PM
markss28 markss28 is offline
Default 700r4 problems
I have a 700 r4 in my 73 camaro. I cant seem to get the tranny to stay in gear long enough. When I floor it it will rev to about 3800 RPM and then shift to the next gear. When Im passing it wont kick down. I am going to replace the kickdown cable as I fear it is not working. I was told that the braket that holds the cable has to be really strong and as straight as possiblbe.
Does any one know of a company where I can buy both peices?
Never Stay Stock
Old 09-16-2006, 05:31 AM
ProTouring442's Avatar
The 700R4 doesn't have a "kick-down" cable, the cable you see controls several functions inside the tranny, not just kick-down. This cable needs to be adjusted properly or it can damage the tranny due to improper pressures inside the tranny. The cable also does not have a linear pull, but is pulled at a specific ratio (varies through the pull I think). We got our brackets through Summit, TCI was the brand if I remember correctly.
What sort of induction are you using?
Shiny Side Up!
Bill
'72 442 "Inamorata"
Old 09-16-2006, 07:09 AM
Steve68 Steve68 is offline
Its called a TV cable "Throttle Valve" cables available from GM, brackets aftermarket,
Old 09-16-2006, 07:21 AM
Hey yeah! That's it! I couldn't remember the name this morning. Maybe I shouldn't respond to posts until after I drink my coffee!
Shiny Side Up!
Bill
'72 442 "Inamorata"
Old 09-16-2006, 12:18 PM
907rs's Avatar
907rs 907rs is offline
As was said earlier, it's imperative that the TV cable be adjusted properly.
Here's a link that I've found to be very useful:
http://www.tvmadeez.com/article/index.php
Bill
Old 09-18-2006, 06:55 AM
Don't worry Bill(442) we all help, when were short of ... braincells!!!
and like the other Bill said, ADJ is important!!!!!
Old 09-19-2006, 02:55 PM
Great thanks for the help. I am ordering a new TV cable and Braket from Lokar today. I hope this fixes the problem.
Never Stay Stock
Old 09-20-2006, 12:21 AM
leos67bird leos67bird is offline
Default Fix for TV adjustment problem
I have delt with this before, and in my research found that Bow Tie Overdrive has a kit to correct the problem. Call Bow Tie Overdrive @ 760-947-5240 or go to www.bowtieoverdrives.com.
Hope that helps!
Old 09-22-2006, 11:46 AM
JUSTANOVA JUSTANOVA is offline
Hope that helps!
I second bowtie overdrives, got the whole setup(from the cable, brackets all the way to the plunger and spring in the valvebody) from them for my dads car, good stuff.
