Old 07-07-2022, 11:57 AM
4GOTNPNY 4GOTNPNY is offline
Default tremec 6060 conversion
im putting a 6060 in my 78 mustang and wanted to convert the output shaft and tail housing to a magnum so i can run teh standard speedo gear and not have the remote shifter the BK5 conversion is out of stock at DandD does anyone know where i can get a conversion kit?
Old 12-10-2022, 06:12 AM
Thanks to texts drivetrain performance got all the parts needed I know have a magnum for my coupe
The Following 3 Users Say Thank You to 4GOTNPNY For This Useful Post:
camcojb (12-10-2022), dhutton (12-11-2022), jarhead (05-20-2023)
Old 12-13-2022, 09:55 AM
gnx7's Avatar
gnx7 gnx7 is offline
Make sure you get rid of the factory 6 bolt shifter because it shifts sloppy and the seal will fail eventually. They all fail.
Old 01-31-2023, 01:15 AM
CarlC CarlC is offline
Yep. I'm on the third one.
Look real close at the boot in the above photo. It's failed.
http:www.vaporworx.com
Old 01-31-2023, 07:22 AM
Thank you for the advice I will look into a new shifter I am happy with the result!
The Following User Says Thank You to 4GOTNPNY For This Useful Post:
