Old 07-22-2022, 01:04 PM
jeeper90 jeeper90 is offline
Default 1967 Camaro brakes donor car
I have a 67 camaro it had drum brakes but the new spindles are for stock disk. . PWhat is a great donor car for large brakes? Iooking for something at Pick-a-parts type salvage yard to save some money.
Ok, last question, who bake brackets for the donor brakes?
Chris
Old 07-23-2022, 10:09 AM
bretcopsey bretcopsey is offline
I would probably avoid “junkyard” rotors and calipers when you can get decently priced parts store parts. There are a couple options for brackets to use C5/c6 Corvette brakes on stock spindles and rear axles from Kore3
Front http://www.kore3.com/proddetail.php?prod=10083-01
Rear http://www.kore3.com/proddetail.php?prod=10275-01
It has been a while but I think the 67 with non-staggered shocks in the rear may be an additional challenge. Feedback about Kore3 has always been good-you may want to discuss your project with them before buying anything to avoid any pitfalls.
The Following User Says Thank You to bretcopsey For This Useful Post:
camcojb (07-23-2022)
