Old 08-24-2022, 05:19 PM
elwaupo elwaupo is offline
Default Cooling Problems
I have a 69 Camaro with a Snper equipped 350/700R4 and I’m having problems with the cooling. I have a 3 row aluminum radiator and fan shroud, replaced the water pump, thermostat, swapped out the old fan with a 2500 cfm fan and I can’t keep the temperatures down. The only thing I haven’t replaced is the radiator, can that be the problem? It was new in 2009 and I don’t have hardly any miles on it. I do have a 4 row stock radiator I can try.
Old 08-24-2022, 08:36 PM
camcojb camcojb is offline
When does it overheat? Idle, cruising down the road, all the time?
dhutton (08-25-2022)
Old 09-02-2022, 07:39 PM
andrewb70's Avatar
Is the Sniper controlling the timing? Has the timing been synchronized? If the Sniper is not controlling the timing, what's the timing at idle?
Andrew
Instagram @dr__efi
I offer remote Holley EFI tuning.
I deliver what EFI promises.
Please get in touch if I can be of service.
My YouTube Channel
