Old 02-07-2023, 11:01 AM
thedugan's Avatar
thedugan thedugan is offline
Default New Vintage Air install and fixing a leak
Look for guidance on tracking down a leak (or leaks) in a brand-new Vintage Air install. The system is dry and has nothing in it. Shop went to charge it but said they couldn't because of a leak. What is the best way to track down where the leak is coming from? I would rather not have to check every fitting and still not be sure if the system is tight.
Doug L.
68 Camaro RS/SS Conv. LSA/T56
67 Camaro RS LS2/T56 "NutKse"
Old 02-07-2023, 11:54 AM
camcojb camcojb is online now
I used the inexpensive dye you add with a black light for a friends, worked great. R134 dye was about $10 and the UV flashlight was $20 on Amazon.
The Following 2 Users Say Thank You to camcojb For This Useful Post:
130fe (02-07-2023), zz430droptop67rs (02-07-2023)
Old 02-07-2023, 02:13 PM
zz430droptop67rs's Avatar
zz430droptop67rs zz430droptop67rs is offline
Never heard of shop that would turn down work!
I did A/C work for many years and found it's gravy. Easy money.
Like Jody said you can test for leaks at home. I would avoid any shop that can't find a Freon leak and repair it. Crazy talk!
Old 02-07-2023, 03:41 PM
dontlifttoshift's Avatar
dontlifttoshift dontlifttoshift is online now
To use the dye you have to charge it.
Buy a cheap set of gauges, used or hammer freight, whatever. Adapt the manifold where the yellow service hose would go to an air chuck and connect it to shop air. Now you can easily pressurize the system and spray it with soapy water and look for bubbles to find a leak. You can also just leave it pressurized to make sure it holds. I have had several cars pass a vacuum test and fail this test so now I do both on new installs.
Donny
The Following 2 Users Say Thank You to dontlifttoshift For This Useful Post:
camcojb (02-07-2023), Hotwire (02-08-2023)
Old 02-07-2023, 05:32 PM
thedugan's Avatar
Thanks guys. Shop offered to track down the leak. I’d rather figure it out myself so I told them to hold off.
Doug L.
