Old 03-29-2023, 04:21 AM
paulk68 paulk68 is offline
Default Holley adjustable clutch master
has any used the holley adjustable clutch master with the DSE firewall bracket? just curious how you mounted it. seems the Ubolt that comes with the clutch master is larger than the holes in the DSE firewall bracket. should I open up the DSE bracket holes or use smaller bolts on the clutch master? any tips would be great thanks.
Old 03-29-2023, 10:01 AM
camcojb camcojb is offline
Personally I would open the holes on the bracket and use the larger bolt size from the master cylinder.
