Old 04-16-2023, 06:16 AM
572Camaro's Avatar
572Camaro 572Camaro is offline
Default Red tail light lenses
I am trying to help a friend improve the brightness of his factory tail lights on his 1940 Chevy Special Deluxe hot rod.
We have tried LEDs, halogen 1157 bulbs, chrome backing inside housing, and etc.
Problem is available lenses are thick dark red glass and block excessive light.
DOES ANYBODY KNOW of a company that can machine red plastic in the lense shape?
Any other thoughts?
3D printing is not a best option here.
Old 04-16-2023, 08:58 AM
camcojb camcojb is offline
These are supposed to be much brighter than a standard LED, but it'll be a pricy test.
https://www.gtrlighting.com/1157-bri...lbs?quantity=1
572Camaro (04-16-2023)
Old 04-18-2023, 05:35 AM
Hotwire Hotwire is offline
Have you checked wiring? Good ground? Getting full voltage when brakes were applied?
You might need to step up the lumens output to get a brighter output. Most LEDs have don't have a lot of yellow/red light emission and aren't very bright behind a red lens.
That being said, I wasn't happy with the dome light in my 64 so I soldered cheap LED light assemblies together. I used copper house wiring and formed them to fit behind the stock lens. Might be something you could try?
Removed caps from 2 assemblies and formed wire to tuck behind the dome light caps.
https://flic.kr/p/2mWoP2F
Finished, had to slightly bend the assemblies into a curve to fit the stock lens
https://flic.kr/p/2mWvuNu
Great result
https://flic.kr/p/2mWugzB
*Jeff*
Project Salty - 1964 4 door Malibu, beaten, neglected, red headed foster child
Cammed LQ4 / T56 Swap Project Thread <-click to read! 😁
The Following User Says Thank You to Hotwire For This Useful Post:
camcojb (04-18-2023)
Old 04-18-2023, 06:07 AM
dontlifttoshift's Avatar
Have you tried these? https://www.speedwaymotors.com/Techn...hoCp1MQAvD_BwE
I'm not crazy about how these look and prefer the glass lenses but if you going to make lenses anyways this seems like a simple solution.
The real problem is that they are small.......and low. If the car doesn't already have a 3rd brake light, I highly recommend it.
Lenses are typically machined from acrylic and then candy painted on the backside, then you also machine a diffuser from the same material.
Donny
The Following User Says Thank You to dontlifttoshift For This Useful Post:
Old 04-18-2023, 11:18 AM
Camaro6869 Camaro6869 is offline
check with digitails they make LED light panels, something is bound to work
