Old 07-07-2023, 11:30 AM
572Camaro's Avatar
572Camaro 572Camaro is offline
Default 68 Camaro subframe
My latest project is helping a friend rebuild a 68 Camaro to just drive.
It’s a driver with 15” wheels and nothing wide, not even minitubbed.
It will end up with a 502ci and auto trans(?).
He asked me for subframe recommendations with a budget.
Questions:
Should we get a new stock subframe? If so, where from.
I personally think we need a stock subframe with the exception of upper tubular A-Arms and coil over shocks. Can it be purchased? I can TIG weld in the DSE modification, but I can only volunteer so much.
Please help us.., and don’t be shy.
Old 07-07-2023, 12:07 PM
dontlifttoshift's Avatar
Is there an existing subframe? What's wrong with it? If nothing run it with a RideTech street grip and a decent steering box.
If you don't have a stock sub to start with and coil overs are a must have, I think the math is going to be really close to putting an aftermarket clip in the car. Big Block makes that an even easier decision for me because header/steering box clearance.
Donny
The Following 3 Users Say Thank You to dontlifttoshift For This Useful Post:
572Camaro (07-07-2023), camcojb (07-07-2023), dhutton (07-07-2023)
