Old 12-23-2023, 04:56 AM
Default rod/exhaust hanger bender
Anyone have a suggestion on a rod bender or exhaust hanger bender? I was looking at the Eastwood piece https://www.eastwood.com/eastwood-rod-forming-tool.html Seems ok. I wasn't sure what else might be out there though.
Old 12-23-2023, 07:35 AM
thedugan's Avatar
thedugan thedugan is offline
I saw this one awhile back. I don't own one so can't tell you anything about it.
https://www.tmrcustoms.com/collectio...lat-bar-bender
It's expensive compared to the Eastwood bender.
Doug L.
68 Camaro RS/SS Conv. LSA/T56
67 Camaro RS LS2/T56 "NutKse"
The Following 2 Users Say Thank You to thedugan For This Useful Post:
camcojb (12-23-2023), WSSix (12-23-2023)
Old 12-23-2023, 08:05 AM
camcojb camcojb is offline
I have the Eastwood one, and it works well.
The Following 2 Users Say Thank You to camcojb For This Useful Post:
jarhead (02-03-2024), WSSix (12-23-2023)
Old 12-23-2023, 08:38 AM
That does look nice. However, it doesn't do radii like the Eastwood one which is what really drew me to their product since I will most likely need to bend the rod so it connects to the side of 2.5" pipe.
Thank you, both.
Old 12-23-2023, 03:42 PM
dhutton dhutton is offline
I have this one but I like the looks of the Eastwood better.
https://www.trick-tools.com/Huth-Man...HMRB6017-11253
Don
The Following 2 Users Say Thank You to dhutton For This Useful Post:
Old 12-24-2023, 06:37 PM
Jody, what's the diameter on your exhaust hangers? I'm so far only find 0.47" diameter and the Eastwood bender says it's only good to 0.375". Did it still work well with 0.47" rods? Thanks
Old 12-24-2023, 08:06 PM
Amazon has several different universal 3/8" hangers.
https://www.amazon.com/Universal-Exh...0BPCXDJGP&th=1
Fluid Power (12-27-2023)
Old 12-25-2023, 04:46 AM
What about the rubber hangers? All I am finding there is the 12mm holes. I would think these had to match. Do they not? This is my first time trying out these components so I appreciate the guidance. Thank you
Old 12-25-2023, 08:55 AM
I think mine came with the Magnaflow exhaust. They don't have to be super tight, the inner/outer knobs won't let them slide off.
Here's a place with 3/8 and 1/2" hanger rods and rubber.
https://www.aceraceparts.com/blogs/n...0pack%20of%202.
Ketzer (01-18-2024), WSSix (12-25-2023)
Old 01-17-2024, 07:25 PM
I looked at the Eastwood bender again and realized it said 1.25 diameter bends instead of radius. I'd like to be able to bend the hangers I got so they wrap around the pipe a little bit. I ended up making a tool with some scrap and a short 2" steel pipe union. The outer diameter of the union is actually only 2.375" but that should be close enough for 2.5" exhaust pipe.
I'll heat the hangers up with my torch and bend them around the pipe. At least, that's the plan. We'll see if it holds up or not. I got to try out my tig skills on a real project at least instead of just test pieces. My skills are not ready for Instagram. If they hold, that's all that matters to me.
Ketzer (01-18-2024)
