Old 05-06-2024, 06:41 AM
Sales@Dutchboys's Avatar
Default Wegner Automotive Dry Sump LT4 Accessory Drive Kit W/ ATI Damper
Item Location (City/State):Vicksburg Mi
Price:$3,200
Description:Wegner LT4 accessory front drive. Crank hub used for mock up only. Nothing else has even been out of the box. Buyer can pick there crank supercharger pulley size. dont wait for extended lead times, get your project finished!!!
Component Specs & Options
Finish Options - Black Anodize or Machined Finish
170 amp single wire alternator with internal fan
Runs on Wet Sump Alignment
Power steering pump from PSC Motorsport, GM Type 2 with -6 and -10 AN Fittings, Available in High or Low Flow
Independent 8 Rib Supercharger Drive Belt
Optional S.S. Supercharger pulley 2.445"
Optional 3% 8% or 15% Overdrive Crank Pulley
Optional 225 Amp alternator available ( Requires longer belt)
WAK060 Kit Includes the Following
OEM Tensioners
Gates Belts for Reliable Performance
Billet Brackets and Pulleys Made from 6061-T6 Aluminum
Supplied Stainless Steel Mounting Hardware
ATI Damper
dutchboyshotrods.com
269-823-2967
The Following User Says Thank You to Sales@Dutchboys For This Useful Post:
camcojb (05-06-2024)
Old 05-07-2024, 06:04 AM
We also have the correct hub to make this a Wet Sump kit if needed.
269-823-2967
camcojb (05-07-2024)
