Old 07-06-2024, 03:21 PM
MODO Innovations's Avatar
Default CTS DBW Bracket for 88-98 GM truck
Were are happy to release some new part numbers.
We have a drive by wire adapter plate that works with the Cadillac CTS or GM Performance Connect and Cruise accelerator pedal that fits the 1988-98 GM truck (OBS). This will also fit 1973-87 GM trucks (Square Body) however, it is a tight fit due to the a/c duct work.
Like our other dbw brackets, this one has 3/4" vertical and 3/4" horizontal adjustment built into it (a little more than our others). You can make adjustments without having to remove the bracket or the pedal.
These are machined in house using 6061 T6 aluminum and then powder coated in satin black. The kit includes everything you need except the accelerator and the 3 factory gas pedal bolts that mount it to the firewall.
First 3 photos.
Available on our website. DBWP 8898
We also have a gas pedal adapter that allows your pedals to match. We start out with a new reproduction gas pedal, a new clevis pin, a custom made spring and a machined aluminum adapter to tie the new reproduction gas pedal to the CTS accelerator.
Last 3 photos.
Available on our website. TRKGPA CTS
Shannon
Modo Innovations
940-391-9002
