Old 07-06-2024, 03:46 PM
MODO Innovations's Avatar
Default C6 DBW Bracket for 1973-98 GM trucks
More new products.
We now offer a drive by wire adapter for the C6 Corvette accelerator pedal for the 1973-98 GM trucks, from the square bodies to the OBS.
This one also has both vertical and horizontal adjustable of 3/4". The pedal can
be easily adjusted without removing it or the bracket, just loosen the bolts on the base and the nuts on the accelerator.
Machined from 6061 T6 aluminum and powder coated in satin black. Everything is included except the accelerator pedal and the 3 bolts that mount the gas pedal to the firewall. First 3 photos below.
Available on our website.
DBWP 7398
Next we have a gas pedal adapter that allows you to run a factory style truck gas pedal with the C6 accelerator. This kit consists a new reproduction gas pedal that has been machined to fit the C6 accelerator arm, an new clevis pin and a custom made spring. The only modification that will be needed to the accelerator arm is the hole needs to enlarged for the new clevis pin.
The last 3 photos.
TRKGPA C6
Shannon
Modo Innovations
940-391-9002
