Old 09-01-2024, 11:24 AM
NickBurns NickBurns is offline
Default Quick question with an LT4 in a CTS - is the hood different than a ZL1 lid ?
I remember ports being in the back on the CTS - Trying to see if we can make this work in a 68 Camaro Convertible with a roadster chassis … Thanks in advance ! Also the drive system because the A/C condenser might bus the frame like it did with my Ds subframe
Nick's son was last seen finishing up his 1968 Pro Touring Camaro
1968 Pro touring Camaro
ALL DSE Suspension
2017 6.2L made of steel balls
Old 09-02-2024, 08:36 AM
I dont even know what you're asking ... let's talk about buttered sausage
Old 09-02-2024, 09:17 AM
camcojb camcojb is offline
I've seen several first gens with the CTSv lid/engine, so they can fit. If you use the slider engine mounts you get about 2" of front to back adjustability, I'm sure you can set the engine in a place that clears the hoses in back.
NickBurns (09-03-2024)
Old 09-02-2024, 02:54 PM
thedugan's Avatar
thedugan thedugan is offline
LT4 or LSA ?
Doug L.
68 Camaro RS/SS Conv. LSA/T56
67 Camaro RS LS2/T56 "NutKse"
Old 09-03-2024, 10:45 AM
Originally Posted by thedugan View Post
LT4 or LSA ?
LT4
ALL DSE Suspension
Thank You !!!
ALL DSE Suspension
Old 09-03-2024, 10:47 AM
I believe the Holley mounts are all the way forward, used those on a buddies LSA swap and gave lots of room at the firewall side. I used the sliders to get the motor as far back as would work for mine. What exactly are you talking about at the rear of the LT4? I thought all of them had the water lines/manifold up front CTS V or not.
NickBurns (09-04-2024)
