Old 11-13-2024, 05:32 PM
FUUKN PHATGUY FUUKN PHATGUY is offline
Default A body Drum hubs for big brakes
Anyone used factory drum brake hubs to put 14" rotors on the front of their A body GM?
I got new factory hubs and the OD of center is bigger than ID of rotor.
I'm just wondering about cutting the OD of hub down (did you have to?)
Hoping i didn't buy new 2nd hand incorrect rotors
Sent from my SM-S921W using Tapatalk
Old 12-07-2024, 01:54 PM
As it sits now, the factory drum brake hubs DO NOT accept slip on rotors without the rotor being turned down.
This is because the factory drum hub does NOT have enough meat to be skinnefied...
This is info I could NOT find out definitively on the net before this fuukn fiasco...
Hope this helps someone
The Following User Says Thank You to FUUKN PHATGUY For This Useful Post:
camcojb (12-07-2024)
Old 12-22-2024, 05:47 AM
130fe 130fe is offline
Thumbs up
Turned down rotors work fine. Put in some longer 1/2 screw in studs (or 12mmx1.5) as well. This thread has some good info.
https://www.camaros.net/threads/drum...pgrade.486552/
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
The Following User Says Thank You to 130fe For This Useful Post:
camcojb (12-22-2024)
