Old 09-30-2006, 07:52 PM
Mike Hall's Avatar
Mike Hall Mike Hall is offline
Default Moving the Master cylinder?
Any ideas on how I could move the MC from the firewall? The twin turbo setup I want to build will place the turbos in each rear corner of the engine compartment and the MC is in the way. I thought about some wilwood pedels but would those be any good for street use? Anyone have any good ideas?
Mike
Old 09-30-2006, 08:00 PM
fatlife's Avatar
fatlife fatlife is offline
Banned
mount it under the dash or in the cowl like a hotrod. I don't suggest this but it can be done
Old 10-01-2006, 09:42 PM
syborg tt's Avatar
the other option is to mount it to the frame with a floor mounted pedal
marty-mj
Old 10-01-2006, 09:57 PM
comp-spec's Avatar
We have the pedal up under dash and were having a hard time get enuff pedal psi to the brakes.
