Old 10-03-2006, 04:56 PM
slownova slownova is offline
Default FI for olds 455
does anyone know of a kit out or a bolt on intake for a olds 455? i know you can retrofit it to a intake but i wondered if there was one i could just buy and stick on. also if anyone knows the cost that would rock. i want it to clear a stock ram air hood also. thanks.
Old 10-03-2006, 05:51 PM
Hammered's Avatar
Hammered Hammered is offline
I don't know of an intake available, but keep in mind that most throttle bodies are between 0.25" and 1.25" shorter than the factory Q-jet (which was 3.25" base-to-air cleaner flange). In other words, you can tolerate a little taller intake.
1967 Firebird Convertible, 462, EFI, TKO
My Firebird
Old 10-03-2006, 08:46 PM
ah good imput, thanks
Old 10-04-2006, 06:07 PM
cutlasskid cutlasskid is offline
http://www.mass-floefi.com/mass-flo.html not sure if this is what you want but take a look
Old 10-04-2006, 07:27 PM
tyoneal's Avatar
tyoneal tyoneal is offline
Call Edelbrock, they have a lot of experiance with the olds 455.
Check out November 2006 CarCraft. (Page 38) Thay have a bolt together Olds 455 build. It is made for a Cutless. Should do high 11's @ about 115 in a 3800 pound car.
500 hp at 5400 rpm
570 ft pounds of torque at 4000 rpm's!!!
Hope this helps.
tyoneal
