Old 10-08-2006, 09:08 AM
deuce_454's Avatar
Default suspension analyzer software??
ok here is the thing ive been talked into (a great many thanks for the help P.T.442 by the way) to try and run impala UCA's with B-body spindles on my G-body. and therefore i need a way of figuring out where to weld the mounts the frame...
can anyone outhere help me with g-body IFS measurements, impala arm dimensions, B-body spindle heights, and almost importantly what software to buy??
what camber curve should i ideally shoot for.. should the upper shafts be paralell?? what angle to get best antidive compromise??. (id like to turn it into a real cornercarver, 1g lateral or as close as possible,
or is there a vendor who can do the math for me??
Old 10-08-2006, 10:28 PM
novanutcase's Avatar
Performance Trends Suspension Analyzer
http://www.performancetrends.com/SuspAnzr.htm
Be prepared to not know some of the specs they will want! Make sure you understand the terminology and what it means to your suspension. I'm not sure of how much you know of suspensions but a good place to start is to buy Herb Adams "Chassis Engineering" book.
Good Luck!
Old 10-10-2006, 12:23 AM
deuce_454's Avatar
thenx... i have decided to stick with somthing proven... the whole task seemed a little daunting so i went with ATS/global west suspension instead..
Old 10-10-2006, 05:05 PM
Great Choice! Good Luck!
