Old 10-11-2006, 04:04 PM
Hitman's Avatar
Hitman Hitman is offline
Default DSE coil over kit with custom crossmember
Here Is one of the projects on the go at our shop that I think you guys might like. Custom front crossmember with a LS1 backed with a 6 speed retaining stock floor, tunnel and fire wall. In a 1969 Camaro.
Old 10-11-2006, 05:20 PM
ProTouring442's Avatar
Neat! Looks good!
Shiny Side Up!
Bill
'72 442 "Inamorata"
www.fquick.com/ProTouring442
Old 10-12-2006, 03:06 PM
Hitman's Avatar
Thank you, It took alot of measuring and thinking to pull it off. It is so much easier when you can just cut floor to make it fit.
Old 10-13-2006, 01:57 PM
BIG SHOOTER BIG SHOOTER is offline
Thumbs up
Killer work looks great, keep up the good work.What is the customer using for power & is there A/C on the car
Old 10-14-2006, 07:03 AM
Hitman's Avatar
He is going to put a Novi supercharger, intercooled with meth injection. All corvette accesories. He plans on making at the wheels 850 to 900 hp with a/c.
Old 10-14-2006, 09:01 AM
PT Dave PT Dave is offline
Looks great !!
What Headers are you using on your Project Car ??
Old 10-14-2006, 03:49 PM
Hitman's Avatar
We are using stainless works headers. Very nice workmanship on them.
Old 10-14-2006, 07:19 PM
Datsbad's Avatar
Datsbad Datsbad is offline
Many times I see guys posting about cutting the floor in a 69 to fit the T-56 , However I have done this a few times and have never had to cut one yet .
""DEMON"
6.1HEMI/TKO 5 SPEED
CCW Black edition/BFG tires
Mini tub/AIR Ride
RMS Suspension
CURRENTLY FOR SALE !!!
Old 10-14-2006, 08:07 PM
awr68's Avatar
awr68 awr68 is offline
I had to raise my tunnel to fit my T56 simply because I used .5" lowering body mounts...never will I do that again!!
Hitman the car looks killer!!
Tony
'68 Camaro
Old 10-15-2006, 10:17 AM
Hitman's Avatar
We used stock height aluminum body mounts which helped. The problem we found was with stock steering and the corvette a/c is that you have to cut so much out of the original crossmember that there was nothing left.
