Old 10-16-2006, 04:43 AM
evilzee28 evilzee28 is offline
Default evil zee project update
Knowing how you guys like pics of work in progress, here's a few of my '69 Camaro taken a while ago. The body is in pretty good condition really & as parts for it are hard to come by in the UK & the repro stuff doesn't fit too well anyway without a lot of work, I decided to repair all of the original sheet metalwork rather than buy in new. The bottom of the o/s front fender was a bit rusted so I cut it all out & replaced it with new sheet steel, the front of the fender also had a bit of tin worm so that was also replaced. The pics were taken before final metal shaping. As the shell wasn't at the 'shop, I decided to tack weld the fender to the door to align everything up prior to final repairs & it now fits perfectly & is primed ready for paint.
Old 10-16-2006, 04:49 AM
Primed & ready to fit
Old 10-16-2006, 05:14 AM
jannes_z-28's Avatar
Great work Nigel!
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
Old 10-16-2006, 06:04 AM
Thanks Jan, how's yours coming along?? Here's a pic of the steering wheel centre I made. I'm gonna keep the original RS wheel but have the rim padded & stitched in black leather with this polished aluminium centre to cap it off. I like to make/fabricate stuff rather than just go out & buy it off the shelf, so the car's gonna have quite a few one off touches.
Old 10-16-2006, 07:04 AM
That center looks awesome, I have ideas on homemade stuff myself on some details. Let's see what happens during the winter.
About my car, look here: https://lateral-g.net/forums/showthread.php4?t=6327
Jan
Jan Suhr
Stockholm, Sweden
Old 05-09-2007, 11:44 AM
Here's a few more update pics. The cross ram will have injection fitted inside the plenum chamber & the carbs will act as throttle bodies when finished, so that it all looks original. The Offenhauser logos have since been removed & a winters foundry casting added,along with the removal of the throttle linkage bracketry, just to fake it to look like a genuine, rare, GM cross ram.
Old 05-09-2007, 11:49 AM
Here's a close up of the rusty holes around the rear screen aperture. Because it's hard to get body panels here in Britain I decided to cut it all out & weld in new steel.
Old 05-09-2007, 11:51 AM
here's the new formed steel being tacked into place.
Old 05-09-2007, 11:53 AM
All seam welded up ready for the lead loading/body soldering.
Old 05-09-2007, 11:55 AM
There was rust around the joint between the 1/4 & hinge panel, so I cut out the rust, formed a new piece & welded in a new section.
