Old 10-22-2006, 04:27 PM
fjb2069's Avatar
fjb2069 fjb2069 is offline
Default 69 project update
Update of camaro project. Not in cronological order yet, but you should be able to get the gist!
www.altronicsinc.com/pages/camaro
Old 10-22-2006, 05:28 PM
EFI's Avatar
EFI EFI is offline
Looks Great!
How about some specs?
Old 10-27-2006, 09:56 AM
scrap'nsyclone's Avatar
scrap'nsyclone scrap'nsyclone is offline
What size rear tire is that?
1991 GMC Syclone
1955 Chevrolet Bel Air Hardtop
Old 10-27-2006, 10:19 AM
fjb2069's Avatar
335/30 r20
Old 10-27-2006, 10:30 AM
fletcherscustoms fletcherscustoms is offline
Are you using the stock outer wheelhouses?? I have a set of 20x12 for my car. But just doesn't appear to be enough room under there with the stock wheel well on the outside. I am using the DSE mini tubs also
Old 10-27-2006, 10:56 AM
fjb2069's Avatar
Yes the outside is stock. I am running a 11.5 inch wheel, but I do not think I would have a problem with a 12"
I have a set of 325/25 r20 PS2 also that I sized orginally, but had a hard time finding an 18" front tire with a mathcing profile, so I got the bigger tire (335/30 R20). The 325/25 R20 tires are shorter 26.4" and not as wide by a good 1". I still have them if you want them. They will fit easier.
Have you actually put them on your car? I seem to have a desent amount of room. Where are yours hitting?
THe one thing I did on the outer wheel well is weld in a piece of 1/4" bar stock around entire opening instead of "Rolling" the lip.
Old 10-27-2006, 11:01 AM
All I have done is basically stick the tire up in the wheel well and seen that it hit. I have been so busy with customers I haven't even got the chance to mount the wheels to the tires. I am planning on doing the same thing with the 1/4" rod. We do it often on lowered and air bagged vehicles that we cut the inner fenders out of.
