10-26-2006, 07:57 AM
wooha.. found an sb2.2 engine
i just accidently stumbled upon an enginebuilder who builds engines from used nextel cup parts.. how does this sound:
355 – 360 cubic inches Compression ratio 11:1 runs on pump gas
Block: Race Prepped Chevy BowTie, 4 Bolt Mains, Splayed Billet Caps
Pistons: Forged Aluminum Alloy, J&E or equal, Bore 4.125
Crank: Billet Sonny Bryant, Stroke 3.335, 32-45 lbs. 1.88 to 2.1 rod journals
Rods: Carrillo or Lentz 6.20” H beam. Carr Bolts
Jesel Belt Drive Timing Set
ATI Balancer
Heads: SB2.2CNC Ported Aluminum Chevy Cylinder Heads w/ Del West 2.150 Titanium Intake Valves, 1.600 Titanium exhaust valves, Comp Cams triple valve springs, Titanium retainers and keys, Copper Berylium Valve Seats, Heads Flow 390 cfm @ .700 lift.
Cast Aluminum Chevy Valve Covers, personalized for owner
Jesel shaft mounted roller rockers 1.70 to 2.00 ratio
Cam: Competition Cams Solid roller, 110 Deg. Centerline, Lift= .706 intake and .630 exhaust, Duration 310 intake and 305 exhaust
Lifters: Crower or equal, true roller lifters
Pushrods: CV or equal 3/8” * 9.050 * .080 wall
Wilson Intake manifold and Tapered 4 Hole Spacer 2.00" Part# 004150
Quick Fuel 850 cfm “Drag Carb”
Moroso or equal fabricated sheetmetal drysump pan
Oil System: dry sump, external pump Barnes or equal
12000 dollars give or take a little
Top Quality Headers from Winston Cup teams. Made of stainless steel and most cost over $2500 new. All are complete with collectors and 4 into 1 collectors have fire cones price 650 dollars
usable powerband 2500 to 9600 rpm!!!!!!!
output 650-700 real world dynoed Hp
this would be going in my 80 malibu.. full ATS/global west suspension, boxed frame and delrin bodymounts, big brakes and wheels..
10-26-2006, 09:41 AM
Banned
overkill; high mainetance cam, springs, lifters. You could spend $6K on a 450hp small block, and have all the fun in the world with it, and spend that extra 6K on something that you might actually use and not just have to brag about.  theres a reason these are called "race motors" and its because they belong in race cars, are you building a race car?
10-26-2006, 11:35 AM
deuce,
Is there a website?
10-26-2006, 11:58 AM
as in would have to replace springs/lifters often??
would be fun though, not to mention it would sound badass at 9000+ rpm's
10-26-2006, 01:15 PM
Also keep in mind most of this used NASCAR stuff has the driver's side motor mount bosses on the block milled off for dry sump clearance-- you'll have to run a motor plate. The dry sump will also very likely interfere with your factory frame crossmember, so plan on relocating the pump or notching your frame.
Lots of good used deals on NASCAR stuff. If you put a more reasonable cam in it, use less spring, and keep the RPM's more reasonable, they're great motors even on the street as the valvetrain will live much longer.
Keep in mind that the manifold and runners are very large and designed for continuous high-RPM stuff, so they're usually best paired to lighter cars when given "street duty." They do like RPM's!
1969 Chevelle
10-26-2006, 03:35 PM
Originally Posted by DJW32
deuce,
Is there a website?
there sure is: http://www.musclemotorsports.com/ talked to him.. really nice guy btw.
10-26-2006, 06:35 PM
Their is a LOT of this stuff all over Charlotte. Lot's of GREAT deals on Brakes that could be used on our cars. ALL of it is low mileage, one owner parts!!!
Muscle Motorsports does have a LOT of stuff and a lot of it is old and dated in technology. They are just one of many selling used Cup Parts. They are not cheap in comparison to others who sell in the area. Muscle Motorsports does have a nice facility and the parts displayed for your convience.
You better REALLY KNOW what your looking at as there are lots of "one off" parts that were test parts from Cup cars that make the shelves of these vendors. Pistons are a great example. There are literally 1000's of pistons for sale everywhere in the Carolina's. All high dollar stuff when new with really weird ring and pin locations. Hardly anything you could use on the street. The race teams look at these places as a good way to get some money for their used up parts. Most parts are run 1 or 2 races at most. There is a lot of engine parts for sale. The interesting part is that there are rarely any heads available. The teams want to keep their secrets so we all now know where the power is really made!!
These vendors are a very good source for fittings, wiring, brakes, pads, rotors, exhaust pipes, hoses etc if you are building a G machine. They also have lots of consumable new race stuff on the shelf.
Much of the hardware parts on my vintage race cars are used Cup parts. The best deals are when you are standing there in person. I have bought LOTS of these used parts multiple vendors in person and still would NOT buy any used Cup stuff over the phone without seeing the parts in person.
Mike
Remember "Drive Fast, Turn Heads, Break Hearts"
10-26-2006, 07:28 PM
Do you have any names or contact info for the shops? My dad is retired and would love a road shopping trip.
Thanks,
Chad
10-27-2006, 07:08 AM
wow cc, thats really usefull feedback.. guess i got alittle caught up in having an actual cup engine guess i should find a healthy smallblock and enjoy instead..
10-27-2006, 07:15 AM
That thing will be useless on the street. Torque and power below 5000 will be so low stock Honda's will be kickin your ass. Only way to make the SB2 useable on the street is to add lots of cubes, like 427
BTW, I think Jake has one he may sell.
Frank Serafine
