Old 10-26-2006, 12:23 PM
Beach Cruiser's Avatar
Beach Cruiser Beach Cruiser is offline
Default Priming/Painting e-coat panels
I just finished installing new floors and trunk pan in my 67, I removed the ecoat where I welded, but is it necessary to remove it from the whole panel before priming it?
Old 10-26-2006, 01:22 PM
907rs's Avatar
907rs 907rs is offline
No, just scuff and prime.
Bill
Old 10-26-2006, 07:31 PM
ccracin's Avatar
ccracin ccracin is offline
Check with a PPG rep., I can't remember the product designation off hand but they have a very good sealer in their Global line for adhering to the e-coat.
Old 10-26-2006, 07:47 PM
fletcherscustoms fletcherscustoms is offline
I have been bit by that e-crap more than once. To many times had paint or primer flake or not adhere and go to bare metal and it was prepper properly, which means bad surface prep in the factory. I look at is what does some little chinese or taiwan guy got to lose if he doesn't remove all the oil used in the pressing process before sending it off to be coated. Its always been my way since last bad time, to completly strip the e-crap before an initial coat of epoxy primer.
Old 10-26-2006, 08:38 PM
68protouring454's Avatar
Default e coat
thats why you lacquer thinner test all e coat, if lacquer does not take it off, scuff it or da it with 320 and go, if lacquer attacks it, start stripping
Old 10-27-2006, 08:34 AM
Thanks guys, thanks for the advice. I know you guys like pics, so here are a couple before I did the floors. Hope you guys aren't jealous with my massive state of the art shop!
