Old 10-30-2006, 11:45 AM
superpro787 superpro787 is offline
Default 67 firebird front spring moog P#
Need a moog part number for a 500 to 550 spring rate for 67 firebird?
I have a local spring guy that sell them I just want to make sure I get the right ones.
Jerry
Old 10-30-2006, 01:39 PM
chicane's Avatar
chicane chicane is offline
Moog part number 5536, will yield about a 500 inlb rate at a 14" free length.
I estimate the spring must be cut to 14" free height to equal a stock Camaro height, but this is just a guess. The rate should be around 500 lbs. One end of this spring is like a stock Camaro spring and the other is different. You must cut the non stock or 'pigtail' end. It kind of depends on what you are going to run for an engine, to really get an idea on ride height.
If you were cut them to 13.5" free length, it would yield around a 540-560 rate.
These are available thru WABBCO, in Kerney Mesa, for roughly $68.00/pair.
Old 10-31-2006, 10:57 AM
Thanks a bunch
Jerry
