Old 03-20-2005, 09:38 PM
Jerebus67 Jerebus67 is offline
Default Exhaust question
Need some help on exhaust. Have a 67 Camaro convertible with a DSE minitub kit and narrowed gastank and wondered if someone could suggest what to do with exhaust? With the special bracing of the convertible can somone point me in the right direction? There looks to be no room to put it out the back of the car with the offset springs and gas tank?
Anyone have any experience with this situation?
Thanks for your help!
My 67 Convertible!
ZZ4, DSE front rear and minitub
http://photobucket.com/albums/e143/jerebus67/?sc=1
Old 03-25-2005, 10:54 AM
jannes_z-28's Avatar
Haven't done it myself yet, but I have had concerns about how to route the pipes.
I have seen that some gastanks have the corners cut to make clearance for the exhaust. If you can do it on your tank I think that is the best. It is tight as it is on an non-tubbed car but the route is basically as it is on a stock Camaro when minitubbing.
On my car I have the pipes go over the leaf between the tank and the rearwheel, then down on the outside of the leafspring pointing rearwards.
Good Luck
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
