Old 11-06-2006, 09:34 AM
67ragtp 67ragtp is offline
Default Budnik wheel mounting question
I pulled my wheels off the rear, after torquing them to 85 ftlbs. Required a lot more force to loosen them using a standard 1/2 in drive ratchet. The radius in the wheel socket is getting pretty mared from the ball end of the lug nut and was wondering if antisieze would be good in this spot, or is that a bad thing. Ive never used any type of lubes on lug nuts or studs before, it just seems like these two surfaces really work against each other. Your Thoughts?
Thanks Rich
