Old 11-10-2006, 08:18 AM
mike23109 mike23109 is offline
Default Edelbrock Pro Flow troubleshooting
I've got a Pro Flow on my 383 ProCharged small block. Within the past few months I've noticed my control module will spontaneously reset when I'm in a program screen. This occurs without notice during varying engine loads. I've rechecked all of my electrical connections, looks good. I've contacted Edelbrock and they are at a loss as to what is going on. I've also had them check out my control module. Everything looks good. Any ideas?
Old 11-10-2006, 08:55 AM
camcojb camcojb is offline
I want to know how you're running that system with a blower? It only runs a 1 bar map sensor and you're going into boost, which necessitates at least a 2 bar map depending on boost level. How are you tuning the boost area?
Old 11-11-2006, 07:16 AM
I've upgraded to larger injectors and installed a fuel management unit. It works pretty well. I've had no trouble with until recently.
Old 11-11-2006, 10:07 AM
Well, no idea what is happening with the unit. But if you cannot tune in boost other than using an FMU to up the fuel pressure you are playing with fire.
I would highly recommend getting a different computer like FAST, Gen VII Accel, Bigstuff 3, Autronics, etc. to tune the car with. You could re-use your intake, throttle body, injectors, fuel pump, etc. I would never recommend a system as basic as the Edelbrock on a supercharged engine, which it is not made for.
Not what you're asking, I understand that. But just in case someone else tries to use the Edelbrock for a forced induction I wanted it said.
Old 11-12-2006, 09:11 AM
Thanks for the input, I'll look into those systems. Mike
