Old 11-17-2006, 08:56 AM
yembo77 yembo77 is offline
Default Panhard bar on A-body 4-link
Does anyone know who makes a panhard bar kit for an A-body 4 link using a stock 12 bolt? Anyone think that's a bad or unessecary idea? I'm usng the Hotchkis complte TVS system but would like to add the panhard for extra latral stability at the track. Would it possibly create too much oversteer or does it not do that much?
-Thanks,
Matt Hjembo
95' Impala SS, 70' Chevelle SS, 99' Tahoe Z56 PPV
Old 11-17-2006, 09:56 AM
3kidsnotime's Avatar
3kidsnotime 3kidsnotime is offline
Call Kip Valdez @ metal works performance 303-980-4700 he can help you good luck
Old 11-17-2006, 11:16 AM
Derek69SS's Avatar
It's not really necessary for lateral stability, as the axle really can't go anywhere with the UCA angles as they are. It would help lower the rear Roll Center Height, which is too high on the stock rear, but that's not really going to help much until you have the rest of the setup sorted out.
I'd suggest losing the Hotchkis rear arms, and get some with spherical bearings to allow articulation, and eliminate most of the bind... such as Edelbrock's uppers, and Currie's lowers.
Old 11-17-2006, 02:35 PM
darren@ridetech's Avatar
darren@ridetech darren@ridetech is offline
I would think that the converging angles between the upper bars and the ph bar would serious binding issues.
Old 11-18-2006, 03:08 AM
ProTouring442's Avatar
This would be my thought as well. Hot Rods to Hell (the truck arm guys) make a PHB for the Chevelle frame to go with their suspension, but I wouldn't use it with the stock converging link suspension. If you went with a torque arm though, it looks to be a stout piece.
Shiny Side Up!
Bill
'72 442 "Inamorata"
www.FQuick.com/ProTouring442
Old 11-18-2006, 08:15 AM
Derek69SS's Avatar
Not really, if the PHB is long enough and level, the lateral movement through it's travel would be so little that it wouldn't be a problem. I would, however run rubber bushings in the housing ears, so that there's a little compliance to keep the RCH from moving between the PHB and upper links.
Old 11-18-2006, 08:59 PM
Default sooo...
In the end it is sorta overkill. I don't think the travel would be so severe, vertically, that it would bind, but it does seem like the latral stability could be done in a better way. OK, then I'll most likely stick with something proven instead of adding extra pieces into the mix.
Thanks,
Matt Hjembo
Old 11-18-2006, 09:53 PM
nowukno's Avatar
nowukno nowukno is offline
Shiny Side Up!
Bill
'72 442 "Inamorata"
Check this out
http://www.onrails.us/
My Garage
"DAMN,IM SWEATIN' LIKE MIKE TYSON IN A SPELLING 'B' "
Old 11-20-2006, 03:29 AM
Originally Posted by nowukno
Check this out
Well paint me yellow and call me a school bus! I guess it works.
Thanks!
Shiny Side Up!
Bill
'72 442 "Inamorata"
Old 11-20-2006, 07:17 AM
Marcus SC&C's Avatar
Marcus SC&C Marcus SC&C is offline
Just because someone did it doesn`t mean it was a good idea. Dennis knows better too. If it were mine the spherical bearings in the "ears" would fly and be replaced with stock rubber,then the PHB could set the new RC height and you wouldn`t have 2 conflicting rear RCs. From an engineering standpoint it`s still a bad idea *but* we do have several customers running a PHB on the C4L (with rubber bushings up top) with good results in auto X and track day events. It may be a case of the wrong things,in the right combination for a particular car. I wouldn`t mind experimenting with it some time just for giggles. Mark SC&C
