Old 11-18-2006, 04:29 PM
DAWG's Avatar
DAWG DAWG is offline
Default front leaf spring clipnuts keep stripping!
I am in proccess of redoing my rear suspension
new rear etc.
the clipnuts i got from ground up strip out at 20 ftlbs?
these are for the leaf spring which mount the front of the leaf spring to the body.
anyone know where I can get a set of quality clipnuts that have the actual nut in them like the originals i took out?
SIT DOWN _SHUT UP_HANG ON
Old 11-20-2006, 03:03 PM
DAWG's Avatar
is this post invisible?
Old 11-20-2006, 05:34 PM
907rs's Avatar
907rs 907rs is offline
I'm not in the market, so I wouldn't know where to find the correct ones.
Have you given any thought to ginding the top of the clip flat, then welding nuts to the clips you have?
Bill
Old 11-20-2006, 07:43 PM
1969Crossram's Avatar
1969Crossram 1969Crossram is offline
Default Clipnuts
Check Ebay. I have seen GM ones on Ebay many times. I come across them when I am searching camaro parts.
Old 11-21-2006, 03:02 PM
DAWG's Avatar
I found some grade 8 clipnuts that will work for ACE hardware of all places!
Old 11-22-2006, 11:32 PM
David Pozzi's Avatar
The "good" clip nuts will say "CIP" on them.
Here is the thread on it:
http://www.camaros.net/forums/showthread.php?t=83635
Team Camaro forum members have found the same problem you stated, the nuts strip out before coming up to torque.
Call the vendor and let them know you had trouble with their parts, it's a safety issue and they should do a recall on in my opinion.
David
http://www.PozziRacing.com
Old 11-24-2006, 06:51 PM
DAWG's Avatar
no these are different and you have to modify the holes the clipnuts fit in.
its a done deal and i was able to torque to 50 ftlbs with out stripping the threads.
the OEM nuts specify 30 ftlbs.
these clipnuts i found at ace hardware will take 60 ftlbs.
heres a pic of the installed rear
