Old 11-25-2006, 06:26 AM
mhotel1 mhotel1 is offline
Default do u have 2 cut tunnel on a t56/ls2 swap
Is there a way to avoid cutting up the tunnel on an ls2/t56 install inot 69 camaro? I am tryin to get a handle on this before proceeding with the body work. I do not have the motor and trans to test fit as of yet. I hear yes and no.
Any advice is greatly appreaciated..oh ya I am very new to the forum as well as ls2 swaps if you coul not tell!
Old 11-25-2006, 08:36 AM
camcojb camcojb is online now
I would say it depends on whose engine mounts you use and where they mount the engine. I've done a couple T56 swaps into 69's and there was no tunnel cutting at all. But that was with factory located small and big blocks. The LSX swaps may move the position of the engine which may or may not affect the tunnel.
Old 11-25-2006, 09:47 AM
Van B's Avatar
Van B Van B is offline
I installed an LS2 and T56 into my 67 and the only cutting was a new hole for the shifter. I used ATS engine plates and crossmember.
Jeff
99 Miata LS6
67 Camaro Street Fighter 599 HP L92-SOLD
Old 11-25-2006, 02:18 PM
Datsbad's Avatar
Datsbad Datsbad is offline
I have yet to cut a tunnel . I say no also
Keep us posted with your project
""DEMON"
6.1HEMI/TKO 5 SPEED
CCW Black edition/BFG tires
Mini tub/AIR Ride
RMS Suspension
CURRENTLY FOR SALE !!!
Old 11-25-2006, 05:29 PM
awr68's Avatar
awr68 awr68 is offline
First off, WELCOME!!
What subframe are you using? I beleive if you use a 21st Century frame there is a little surgery to be done...steve would know better than me though. If you are using a stock frame then all the above replys apply....
Tony
'68 Camaro
Old 11-25-2006, 10:44 PM
Thanks for the info... a big help!
Old 12-23-2006, 12:38 AM
But why there are many pictures of new tunnel lid fabrication on DSE project pages ?
63 Z06
Old 12-23-2006, 08:45 AM
couldn't tell you, but I've already done this twice myself in a 69 Camaro, no cutting other than the shifter hole.
Old 12-23-2006, 10:07 AM
lil427z's Avatar
lil427z lil427z is offline
no.
rick k
Old 12-23-2006, 10:30 AM
Efi69Cam Efi69Cam is offline
If you use a standard bell with a adapter plate fitted t56, the trans hits the tunnel from being so far back. Thats were the cutting stories come from.
