Old 11-29-2006, 03:30 PM
sixtnine's Avatar
sixtnine sixtnine is offline
Default Another Tremec Post
Has anyone done any mods to their Tremec which would help it shift better at higher rpms? From my experience the Tremec does not like full throtle, foot thru the radiator, shifting above 6400 rpm or so. I have been told that grinding off every other tooth of the sync gears will help or upgrading to a pro shifted version, which I was told can not be down-shifted, is a fix. Any suggestions? Thanks!
Old 12-03-2006, 01:36 PM
mazspeed's Avatar
mazspeed mazspeed is offline
McLeod has a slick shifter for it that I am having installed in my car. McLeod
Old 12-05-2006, 02:41 PM
67ragtp 67ragtp is offline
I have heard that Amsoil has a lube for the TKO-600, the users did say they noticed a considerable improvement in how the gear box shifted. Maybe/ Maybe not, although for 25 bucks it might be worth a try.
Rich
Old 12-13-2006, 07:04 PM
zcrz zcrz is offline
Default I like mine
I have the tko 600 and the mccleod shifter...I have shifted at 7500 with no problems ever.
Old 12-20-2006, 08:07 AM
parsonsj parsonsj is offline
Default Clutch?
Are you sure your clutch is fully disengaging? If you are using a diaphram-style clutch, higher rpm shifts are affected.
jp
John Parsons
Old 12-24-2006, 10:56 AM
sixtnine's Avatar
Yes, I am using a diaphram style Ram setup. While my car is down this winter I am thinkin about going to a McLeod.
Old 01-23-2007, 09:07 PM
speedshopmike's Avatar
speedshopmike speedshopmike is offline
what parsons said.
check your air gap disengaged when fully warmed up, and check the disc for any warp.
