Old 11-30-2006, 06:50 AM
JMitch19's Avatar
JMitch19 JMitch19 is offline
Default Biggest brakes for a 17" rim?
I'm running 17's up front and 18's in the rear. I want to run 13" rear rotors to fill the opening better. It will have C6 Z51 brakes in the rear. The problem is the C6 Z51 fronts are 13 3/8" and I'm not sure if they will fit under my 17" budniks. If not I will run the 12.8" C5 front. If anyone could tell me for sure if C6 fronts will fit or not it would be a big help.
Jason Mitchell
1971 Camaro 416 LT1 Project
Old 11-30-2006, 07:55 AM
nitrorocket's Avatar
My Touring Classics front brakes (C5 12.8") are real tight in my 17" centerlines. I am thinking 18"s will be absolute minimun for the C6 Z51 setup. You will have to measure the i.d. of the rim right up to the web on the inside to be sure.
Twin Turbo LS1 '71 Chevelle
1000 hp 93 octane street car
6 speed
Old 11-30-2006, 10:04 AM
JMitch19's Avatar
thanks for the reply. That is pretty much what I figured. Damn the Michigan roads for keeping me from running 18's up front.... ]
Oh well, anyone think it will cause a problem running the 13 3/8 rotor out back with a 12.8 up front?
Jason Mitchell
Old 11-30-2006, 12:22 PM
PRRC PRRC is offline
I don't think you will have a problem.As long as you have a adjustable proportioning valve to a just brake bias front to rear.
Tim
