Old 12-01-2006, 10:06 PM
deuce_454's Avatar
Default project g-force to recieve LS1/4l60E
ok all you guys rambling about lsx engines finally convinced me, so ive gone and done it.. just won an ebay auction for a 2000 ls1 with all accessories, cpu and tranny and fuelpump, 2350 dollars.. so all i need now is to get it shipped here and figure out how to shoehorn it into my 80 malibu..
thats all folks
Old 12-01-2006, 10:49 PM
Datsbad's Avatar
Datsbad Datsbad is offline
Let me know if we can help !
""DEMON"
6.1HEMI/TKO 5 SPEED
CCW Black edition/BFG tires
Mini tub/AIR Ride
RMS Suspension
CURRENTLY FOR SALE !!!
Old 12-02-2006, 01:12 AM
McssGmachine's Avatar
McssGmachine McssGmachine is offline
Here's some good info on swapping a ls1 into a G-body. He sell motor mounts and modified oil pans for G-bodys also.
http://www.montecarloss.com/ls1montecarloss/
BRIAN WEST
Old 12-02-2006, 11:16 AM
deuce_454's Avatar
thanx guys.. ive written to the guy on montacarloss, and im definately going to buy the motormounts, unfortunately he requires my oil pan to modify and that means shipping it across the atlantic twice... so perhaps ill try and have it welded here instead... and datsbad... i will definately write if i feel you guys can contribute... i sort of owe you that much for using that name, ill earn it, or rename the car
i think ill give it some fresh bearings for now, and save the rebuild and ballancing for when im done welding the turbo headers..
Old 12-02-2006, 11:25 AM
nitrorocket's Avatar
I would not even touch the bearings. Those motors run 150k with a good beating, I would not worry about it.
What are you doing for headers???
Twin Turbo LS1 '71 Chevelle
1000 hp 93 octane street car
6 speed
Old 12-02-2006, 01:15 PM
deuce_454's Avatar
Default headers
well the g-bodys ive seen on the web with lsx powerplants all have used a set of scoenfield sbc style headder that is adapted to a lex flange, that way the tubes (long 1-7/8 steped tube) fit the chassis and all that realy require attention are the two middle ports that bote have horizontal tubes on the scoenfields, so the cutting and welding can be kept to a minimum... ofcourse if at all possible i will modify the long tube headers i allready have on my sbc to keep cost down and use my money and time on putting together a set of turbo headers, i am actually giving it some thought to make some forms and have a foundry make a small run of "banks/log" style lsx turbo manifolds.. just t4 flange and provisions for external wastegate... and see if i cant sell enough of them on ebay or thru some vendor here to pay for the tools..but it would take some input and thinking... but being a mechanical engineer it really shouldnt be an insurmountable task... but for now im just floating the idea.. but the forms for the cores are rather spendy, especially if it is going to be furan sand cores, that really are the smoothest, but most expensive..
