Old 12-29-2006, 10:06 AM
Musclerodz's Avatar
Default 93-94 LT1 ecm
Bought it a couple years ago and never used it. $125 shipped and i will garuntee it to be good.
Mike Redpath
Musclerodz & Customz
405-735-8405
Mike Redpath
facebook page
Old 12-29-2006, 01:13 PM
69Lt4's Avatar
69Lt4 69Lt4 is offline
Mike,
Do you have the part number? If it's a 16188051 or 16181333. I might be interested.
Kevin
Old 12-30-2006, 10:24 PM
Musclerodz's Avatar
I am pretty sure it is the 051, but I will check tommorrow.
Mike
Mike Redpath
facebook page
Old 01-02-2007, 09:49 AM
Musclerodz's Avatar
Service number is 16159278.
Mike
Mike Redpath
facebook page
Old 01-02-2007, 07:42 PM
69Lt4's Avatar
Thanks Mike,
From I can find out that's a 92-93 PCM.
Kevin
Old 01-02-2007, 10:30 PM
HAULNSS's Avatar
HAULNSS HAULNSS is offline
Wink
I don't want to step on Mike's toes, but it appears that his PCM will not work for Kevin.
Kevin,
I have a spare 8051 PCM from a B-body (94-95 OBD1). The case has been bead blasted and then hit with gloss black from a rattle can. Not perfect, but very presentable. It was a spare for my Impala and Z28 that I no longer need since I sold the Z28.
I also have a friend that can load or setup most any basic configuration. (It is currently set up for a 6 speed B-body) He can change speed limiter, rev limiter, disable VATS, speedo correction, etc.
Let me know if you are interested.
Randy
1995 Impala SS
T56 Six Speed, Wilwoods, Tri-y's,...
1964 Riviera
31k miles
Old 01-02-2007, 10:46 PM
Musclerodz's Avatar
Yeah, I crossreferenced the number and it came up 92-93 which I would assume from a vette. The 051 was used in the 93-94 Z/28 as well.
Mike
Mike Redpath
facebook page
