Old 12-29-2006, 11:41 AM
80Camaro 80Camaro is offline
Default Need help finding correct thr. cable bracket!!
Anyone know of a good throttle and trans cable bracket for my setup... RPM Air Gap, Holley Avenger, "71 thr. cable, and TH350 cable. I've tried a couple that the cable mounts weren't far enough back away from the carb. (too much slack). The one I've had on there for a little while is the little blue aluminum one from Jegs... but it's too flimsy and bends. The one that's supposed to be for a Vortec manifold does not fit well either.
What are you using??
Old 12-29-2006, 03:21 PM
Scotch Scotch is offline
Lokar makes all that stuff, and it's top notch.
Old 12-29-2006, 03:37 PM
Who's a good dealer for them?
