Old 12-30-2006, 10:53 AM
newschool newschool is offline
Default need help with big block heads
I have a 67 Camaro with a 454, engine came out of a 79 C10 truck and still has the truck heads on it. I need some advice on what would be a good set of heads to put back on. Anybody have any good Chevy big block heads for sale?
454
11:1 forged dome top pistons
292 cam lift is either a 530 or 630 can't remeber
750 speed demon card
373 rearend
1.7 roller rocker arms
Old 12-30-2006, 12:16 PM
jski67's Avatar
jski67 jski67 is offline
I've got a 781's for mine...781 or 049 seem to be the best stock
oval ports if you upgrade them to 2.19/1.88 valves. Based
on my research, these are the best bang for the buck street heads.
Although if you have to buy them, then pay for the machine work, you
start to get close to the price of aftermarket iron heads. THEN, if you're
going to lay out that kind of cash, why not just go aluminum?
At least this is the debate I'm having with myself right now...
Anyway, for big block info you should really check out the
Performance forum at [url]www.chevelles.com. Tons and tons of info.
Hope this helps,
Jason
Old 12-30-2006, 04:42 PM
Do you know anything about the 045 heads - late model - will they bolt on to an older block - do you know the valve sizes?
Thanks for your help
Old 12-30-2006, 06:32 PM
ccracin's Avatar
ccracin ccracin is offline
I have a set of GM Performance Parts Aluminum Oval Ports for Sale. They are Brand New on a ZZ502 Crate Engine that has never been run other than the factory test. I'll sell the heads complete with rocker arms and the Intake Manifold for 1595.00. You can go to the following link to see what they are:
http://www.sdpc2000.com/catalog/281/...inder-Head.htm
If your interested PM me or send me an email: [email protected].
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 12-30-2006, 07:09 PM
3kidsnotime's Avatar
3kidsnotime 3kidsnotime is offline
What is the full casting. A GEN 5 and 6 Head if that is what you have you do NOT want to put it on a 4 block the water passage is so large it is in the lifter galley
Old 12-30-2006, 10:27 PM
these are the numbers on the heads
10114156 GM5 A045 CFO 158 & 156
the heads are 91-up oval open chamber gen V&VI 118cc chamber
That listing is from a reference web site
Old 12-31-2006, 07:34 AM
I would not put those on a gen 4 block they will leak water into the valley area, They are also a net valve lash head you can put a bastard screw in stud in, but are not very strong. If you are doing a budget build on a mild motor, find some gen 4 heads if you need to the cheapest place is CP in WI you can get stainless valves springs locks retainers and seals for about $160.00 for bbc in small or big valve combo.
Old 12-31-2006, 08:06 AM
youthpastor's Avatar
Good advise, these heads can make great power-
they are usually found on 73-74 truck 454-lots of them out there-Chris
Old 12-31-2006, 08:22 AM
Efi69Cam Efi69Cam is offline
Gen 6 heads fit the 4 block. gen 5 was the odd-ball.
I'd snap up the offer for the GMPP ovals with intake. That's a smoking deal.
Old 12-31-2006, 10:09 AM
Gen 5 and 6 heads are the same, the diff between a gen 5 is a non roller engine in 96 the engine was changed to a roller engine with raised lifter bores and noted by a composite 6 bolt cover the heads are the same casting number the crank rods pistons are as well, both 5 and 6 are priority main oiling gen 5 and 6 use the same head gasket 4 does not If it is any need I can snap some pics of 5 and 6 heads I have about 45 take off sets, do your research its your money. That is based on production gm iron heads, If you take the gm performance aluminum heads the new ones they will work on all blocks except gen 7 8.1 series, those heads as all ne aftermarket alum bbc heads have small water passages but added material to seal the block on 5 and 6 motors if using them use the correct head gasket.
