Old 01-06-2007, 02:56 PM
deuce_454's Avatar
Default winter turbo project
Ok here is a log that should be finished in a month or so.. the project is a 31 ford roadster that a friend of mine has hadd on the road for some 18 years now.. and every second or third winter its time for a big change, the car is now a full intependent suspension (open hooded) 31 roadster on a 32 frame, TCI ifs, and a jaguar IRS, engine is a 93 LT-4 and tranny is a bowtie overdrives level 4 700r4 the lt4 has been under the influence of a procharger for some years now and the blower pulley has been getting smaller and smallet and belt witer and wider, but it just runs out of steam above 5000 rpm, and the boost never goes beyond 9 pounds, even when we are spinning the blower to redline..
so i started to shoot my big mouth in the spring of last year, talking about how great a twin turbo setup would look on the car.. and now he took me up on it, so i am doing the conversion... he has rebuilt the engine for more boost, 8:1 compression dished pistion, big trick flow heads, crower rods and so on... so i ordered a set of schwartz manifolds, a pair of 57-trim garett t4 turbos, turbosmart 38mm wastegates, nuts and bolts...
i will snap pictures and keep yall updated as it progresses..
Jake: Hit it.
Old 01-07-2007, 04:07 PM
71Nova 71Nova is offline
Sounds Cool. I don't know of anyone that has used those monifolds yet so this will be good to see.
David
Old 01-23-2007, 09:18 AM
deuce_454's Avatar
not really an update yet, but talked to jeff last night and the turbos are expected shortly, he has also assembled all the nessecary parts to throw the turbos on.. wastegates, bolts, washers, flanges and gaskets.. id go so far as to say its a kit.. now if he'd only post pictures
Jake: Hit it.
