Old 01-09-2007, 10:11 PM
protour's Avatar
protour protour is offline
Default BAER 12" front brake kit. Lowering Springs
Selling my front brake set-up.
BAER PBR 2 piston calipers. 12" drilled, slotted, zinc washed rotors, Matching MS, mounting brackets, brake pads, aluminum hubs, bearins, seals, spindle, etc. It is a bolt on affair. Split your upper and lower ball joint and go from there. All the kit needs is 2 brakes lines (-3an to -3an, and whatever length you need. These are roughly 50 bucks for the pair) The complete set-up has roughly 1500km's on it. Brake pads have tons of life left in them. Only reason for selling is upgrading. I am asking $800. (edit price. Knocked 100 off)
Fits the following cars.
1967-69 Camaro/Firebird
1964-74 Nova
1964-72 GM A-Body
SOLD!
Dr. Gas X-pipe 2.5" $30
Dr. Gas turn down tailpipes 2.5" 100$
2" Rear lowering coils (Hypercoil) for 68-72 A-body. Used 1 summer $60
2" Rear lowering HD coils (Afco) for 68-72 A-body Installed but brand new $85
5" x 9.5" 1000lb front afco coils for 68-72 A-body with spring spacer or circle track car. Installed but brand new. $85
-Matt
72 Chevelle. 370ci LS, Forced inductions S476, SpeedTech Suspension equipped, C6 Z06 brakes
Old 01-14-2007, 09:07 AM
3kidsnotime's Avatar
3kidsnotime 3kidsnotime is offline
PM sent on rear springs, Thanks
Old 01-14-2007, 05:35 PM
protour's Avatar
PM and e-mail sent back Jeff.
-Matt
