Old 01-12-2007, 09:36 AM
Turbo-G Turbo-G is offline
Unhappy G-body to B-body Baer Brakes dilemma!
Hi,
This is my first post! I have a technical question...Working on an '84 Buick T-Type and this is what I wanted to do. The Global West Cat-5 upper & lower control arms for the tall spindles and use Baer brakes. I called the Baer tech line (very unhelpful ) and they said "we no longer offer our brakes on the tall spindle, just the stock G-body or drop spindles only. What other brakes are out there that will look good? I have not decided on wheels yet...Any ideas?
Turbo-G
Old 01-12-2007, 09:49 AM
McssGmachine's Avatar
McssGmachine McssGmachine is offline
Give Marcus a call www.SCandC.com. He can give you some options.
BRIAN WEST
Old 01-12-2007, 08:05 PM
GBodyGMachine's Avatar
GBodyGMachine GBodyGMachine is offline
I agree, he knows EVERYTHING G-Body.
Jeff
84 Regal Project GBodyGMachine
[SIGPIC][/SIGPIC]
Old 01-13-2007, 10:58 AM
deuce_454's Avatar
marcus has some tall balljoints that give you the bennefits of the improved camber curve with the oem spindle.... id give him a call... asap
Jake: Hit it.
Old 01-17-2007, 09:56 AM
Marcus SC&C's Avatar
Marcus SC&C Marcus SC&C is offline
Yep, Baer didn`t like the steering geometry issues caused by the B spindles on a G body. They`ll probably stop offering them for A body next because the same issues apply. You`re better off anyway we can do a LOT better than that now! You can do a StreetComp-AFX with tall aluminum spindles with C5 Corvette hub/bearing assys and CNC aluminum steering arms that eliminate 85% of the factory bumpsteer instead of the B spindles. We designed the steerign arms for ATS so we quickened the steering ratio and improved the ackerman angle while we were at it. http://www.scandc.com/suspensions.htm#streetcompafx
Then you can use the Baer 13" GT AFX brake package that has BIGGER calipers than the B body or G body 13" GT but costs $700 less! It sounds to good to be true but it`s just that they don`t have to machine stock spindles,make wheel hubs and brackets. The AFX spindled already have hubs and integral mounts so they`re much less money. The savings on the brakes pays for 2/3 the spindles and adj. tubular upper A arms. Cool huh? You can use GW tubular lowers with that package if you like or these http://www.scandc.com/spohnarms.htm . We have packages that improve geometry and handling with tall ball joints too but since you want a big set of Baers already this is THE hot setup. Mark SC&C
Old 01-17-2007, 12:49 PM
Thanks guys...and thanks Mark (I spoke with you on the phone at length the other day). I think the AFX spindles/C5 brakes will be the way to go. I just don't want to do this twice! Very helpful. Greg
Old 01-18-2007, 01:37 AM
deuce_454's Avatar
good choice!.. thats what im running! except for the SC&C uppers, my car has to pass DOT inspection so i cant run adjustable arms..
Jake: Hit it.
