Old 01-17-2007, 01:16 PM
72novadriver 72novadriver is offline
Default DSE Speed 3 Subframe Complete!
This a complete original ready to bolt in subframe with an all brand new DSE Speed 3 kit. 550lb springs and short steer arms. Along with that I replaced the subframe jack pad aswell as installed a bulkhead inside so you can jack up your car and not have to worry about denting the underside of your frame. This frame was for my Dads Camaro project, but we've decided to go a different route. Asking $4650 for the frame and for another $50 you can have the cart that it is sitting on. Any Questions Please ask thanks!
This frame will fit 67-69 Camaro/Firebird or 68-74 Nova
Billy
Old 01-17-2007, 01:24 PM
Lateral-g Moderator
Nice piece.
Old 01-17-2007, 02:41 PM
67bird 67bird is offline
Default DSE complete subframe
Where are you located? Would you consider shipping?
Old 01-17-2007, 02:47 PM
Nice piece.
Thanks Stuart
I live by Detroit, MI. And Yes shipping can be an option.
Billy
Old 01-17-2007, 05:57 PM
Is the frame painted or powercoat? Also, what is spring rate? Did you do work or DSE?
Old 01-17-2007, 06:00 PM
last question is it equipped with short, medium, or long steering arms?
Old 01-17-2007, 07:23 PM
It is equipped with the short steering arms. Thanks
Billy
Old 01-17-2007, 08:05 PM
The frame is painted in epoxy primer Dp90, The spring rate is 550lbs, I did do the work and have done many of these frames. I work at DSE in the summer time When im not in school. Hope that helps
Billy
Old 01-17-2007, 08:06 PM
Sales@Dutchboys's Avatar
You still work their in the summer when your in Michigan?
or is that when they were in Michigan?
dutchboyshotrods.com
269-823-2967
Old 01-17-2007, 08:23 PM
Yep I go down to NC for the summer, but i also worked for them when they were here in Michigan too.
Billy
