Old 01-21-2007, 02:19 PM
PhilM PhilM is offline
Default LQ9 Question
On the back of the block, there is a place for a tranny bolt. But it is cast solid. Can you drill and tap it?
Thanks.
Phil
Old 01-21-2007, 04:43 PM
JUSTANOVA JUSTANOVA is offline
Thanks.
Phil
I don't think so I think it gets into and oil/water passage
Project EARTHQUAKE:
72 Nova SS, Plans have changed a little:artmorrison front subframe, and rear 3 link, pretty much stock ls1 and six speed with a single turbo for around 550hp. with a few other things mixed in.
current cruiser: "The green machine"
'70 Impala 4drht, 26K original miles, 2" drop springs and large swaybars, drives pretty good for a land yahct
and why do we modify everything...."BECAUSE STOCK SUCKS"
Old 01-21-2007, 04:46 PM
camcojb camcojb is offline
no Phil, I think you end up into the water jacket and/or cylinder. Just use 5 bolts, works fine.
Old 01-21-2007, 07:30 PM
Thanks all.
I figured there was a reason for a missing bolt hole.
