Old 02-02-2007, 06:04 PM
Default Ready to hang- Chicane-LM subframe by ATS
Guys-
We have an assembled subframe for the 67-69 F body/68-72 X body with the Chicane-LM treatment already completed. The frame came from the dry desert of Nevada, which means no rust or body mount rot. We blasted the frame to bare metal, installed it into our welding fixture and completely re-welded the entire frame top to bottom.
During this process we installed the Chicane-LM coil over brackets into this pristine frame for use with Bilstein coil overs. The frame comes complete, ready to hang under your project with the following items:
American Touring Specialties Tall AFX spindles
Global West tubular upper control arms with Del-a-lum bushings and Moog ball joints
ATS modified Global West lower control arms with Del-a-lum bushings, moog ball joints, and welded-in double sheer coil over brackets
Hotchkis 1-1/8" hollow sway bar
Bilstein aluminum coil overs with ATS valving
Hyperco coil springs (475 lb rates, custom rates available in 25lb increments)
GM factory MANUAL (the short ones) steering arms with black powdercoating
ATS (Built exclusively for ATS by Lee Engineering) blueprinted 670 P/S gear box with rack and pinion valving
Moog power steering pitman arm
Moog idler arm
Moog inner tie rods (x2)
GM factory drag link with black powdercoating
Baer adjustable bumpsteer tracker outer tie rod ends with adjusting sleeves and jamb nuts
Global West stock height solid aluminum body bushings with bolt kit
1968 Camaro subframe, fully re-welded with Chicane-LM coil over cages welded into factory upper control arm brackets, powdercoated black
Grade 8 front end hardware kit
We can add on any items you wish from our race inspired 37 degree stainless brake hardlines, to 6 piston AP racing brake packages, T56 crossmembers, engine frame stands, etc. This is the same setup we had on display for the 2006 SEMA show. Jim Shipka is running this setup on his Camaro and Mark Stielow has a similar version with DSE control arms. ( www.onelapcamaro.com )
We will freight ship this setup fully assembled, or in boxes so you can have the enjoyment of assembling the frame yourself. We offer frame building services too if you would rather send in your frame rather than buying another one.
Pricing is going to be $5200 plus freight. I am having issues with our digi cam, so I'll try and post pics on monday.
Tyler
Old 02-17-2007, 01:39 PM
Here are the pics of the parts. The sway bar pictured is NOT included in this kit. It is our prototype Spline-Tune rate adjustable 3 piece splined sway bar. The kit comes with a Hotchkis hollow 1-1/8" sway bar. Frame pics to follow.
Tyler
Old 02-17-2007, 01:40 PM
Here are the pics of the frame. The frame was fully re-welded in our jig, modified to accept our coil overs, and powder coated black. We put our ATS tag on all in house built frames too.
Tyler
Old 02-21-2007, 10:04 AM
Sold.
