Old 02-02-2007, 11:28 PM
TEDDYS CAMARO TEDDYS CAMARO is offline
Default Hydroboost Fluid Question For P.s.
I have a hydroboost set up and I am wondering if If I can use synthetic p.s. fluid.
Old 02-03-2007, 02:03 PM
fakesnake.com's Avatar
fakesnake.com fakesnake.com is offline
If you check out Hydratech Brake systems, www.hydroboost.com, he recommends factory fluids but says that synthetic will work fine.
www.fakesnake.com
1962 Mercury Monterey Convertible
Old 02-03-2007, 05:08 PM
Blown353 Blown353 is offline
Any specific power steering fluid should be fine.
Do not use ATF-- it can foam and cause uneven brake assist and noise.
1969 Chevelle
Old 02-03-2007, 08:38 PM
THANK YOU. I was'nt for sure on the synthetic, but now I am!
