Old 02-12-2007, 09:57 PM
D Rock D Rock is offline
Default 67 Camaro Backspacing Specs
Hey guys,
These are the final numbers I've came up with. Check them over for me and let me know what you think, anything you would change? I'm ordering ASAP.
18x9 Rear with 5 inch Backspacing(I know I can run more but I want a bigger lip.)
18x8 Front with 5 inch Backspacing
Disc brakes front and rear.
Thanks,
Derek
Old 02-12-2007, 11:05 PM
awr68's Avatar
awr68 awr68 is offline
should work fine on a stock subframe and rear axle width car. What are you buying?
Tony
'68 Camaro
Old 02-13-2007, 10:44 AM
Sounds about right. Normally on the front, a 4.875 works, and in some cases a 4.75 works too. On the 9" rear though, I go with a 5.25" and a 275/40/18. That's what has worked in the past for me on almost every camaro I build wheels for.
Old 02-13-2007, 11:51 AM
Budnik Laterals
Old 02-13-2007, 12:03 PM
Sounds good, I think i'm going to go with a 5.25 on the rear now just to get a little extra clearance around the lips.
Thanks Jon.
