Old 02-13-2007, 11:16 AM
SteveMcqueenRules's Avatar
SteveMcqueenRules SteveMcqueenRules is offline
Default Stronger A-body Cutlass frame
Anyone know where I can find how to box my frame?
Also anyone run a k or x member on their frames?
Feel free to post pictures links whatever.
Also if anyone has a nice photo or accurate drawing of a A-body frame suitable for planning upgrades. please submit it.
Thanks guys.
You're gonna be hangin' on for mercy when I get this sucker rollin'- FALFA
Old 02-13-2007, 11:53 AM
3kidsnotime's Avatar
3kidsnotime 3kidsnotime is offline
I will be able to help you on that exact application. I have a 72 cutlass frame at blasting now when it returns it is being boxed I will be posting pics of the job so you will get a exact look at it.
Old 02-13-2007, 01:23 PM
LateNight72 LateNight72 is offline
http://www.chevelles.com/forums/showthread.php?t=147175
Old 02-13-2007, 05:02 PM
Gordz32's Avatar
Gordz32 Gordz32 is offline
We did mine. I had someone bend up some steel plate and made it work. I thought it came out nice. that threadlisted above is great!
Old 02-13-2007, 06:28 PM
Shizzy Shizzy is offline
maybe start with a Convertable frame? its boxed and much stiffer then a hard top frame.
Old 02-13-2007, 08:00 PM
That is a nice clean job That is the most Im doing with some good body mounts. Did you box the lower rear control arm mounts?? I would really like to see some more pics. Looks Great
Old 02-14-2007, 09:50 AM
Do you have nay more pics if so please post em! especially close ups of the boxed in areas you did.
Old 02-14-2007, 11:08 AM
ProTouring442's Avatar
I added supports for the front and rear crossmembers, but nothing different from the standard convertible stuff in the middle.
Shiny Side Up!
Bill
'72 442 "Inamorata"
www.FQuick.com/ProTouring442
Old 02-14-2007, 12:41 PM
Gordz32's Avatar
We didn't box the LCA mounts but I went threw the chassis and welded everything that GM Didn't! Haha. We had to have the chassis straightened and two cracks fixed. the front crossmember area was 2" down and 2.5" over to the pass side. WE got it straight and then welded everything up. I'll try and get some close-up picks today as I have to shift the body over a 1/4" in the front. ( I'm aligning the front sheetmetal) I'll post something up ton for ya.
Old 02-19-2007, 05:13 PM
hectore3 hectore3 is offline
Nice thread. I'm looking to box up my A-body also.
